SUJET : Analysis and research on noise reduction of axial
Analysis and research on noise reduction of axial 1 semaine 1 jour #280814
  • yanyan
  • Portrait de yanyan
The noise of plunger pump is analyzed and divided into human factors and non-human factors. Taking CY14-1B axial piston pump as an example, the working principle is analyzed first, and then the factors causing noise are found out. Finally, some targeted measures are proposed to reduce noise.
Status and classification of hydraulic pumps
Mechanical transmission, electrical transmission, hydraulic transmission and pneumatic transmission are commonly used in industry at present. Hydraulic transmission is widely used in all kinds of construction machinery because of its high working pressure, transmission power and the weight of the actuator is relatively large, can be continuously variable and so on. And hydraulic transmission in a very important energy conversion element - hydraulic pump, is widely used.
Hydraulic pump, as the power unit in the hydraulic system, plays a vital role in the hydraulic system. According to the type can be divided into blade pump, gear pump, plunger pump, screw pump. Among them, the plunger pump is a common, but also widely used high pressure pump, the noise reduction of the plunger pump this problem, there are many scholars and experts are studying.
Related products:
Liquid Ring Vacuum Pump
Vacuum Pump
Heat Treatment Guide,Heat Treatment Equipment
Retourner en haut du topic
Cdiscount : En plus des soldes, 25€ de réduction à partir de 249€7.45mercredi, 08 janvier 2020
Clavier Gamer Roccat ISKU+ : 50% de réduction : 44,90€ au lieu de 89,90€7.29jeudi, 18 janvier 2018
Nombre d'utilisateurs en ligne : 30 Membres et 2730 invités en ligne
KinguinWindows
Chat Config-gamer.fr
Boulikam : Bonjour,
Quelqu'un a-t-il une idée sur la configuration d'une carte ASUS MAXIMMUS IX EXTREME ?
J'ai acquis cette carte il y a presqu'un an et depuis, j'ai rassemblé les pièces après conseils et me suis mis au montage.
Le PC démarre, arrivée dans le BIOS et suivant la routine de réglage ça fonctionne, sauf qu'après, je ne peux pas sortir du
BIOS pour continuer même en redémarrant tout. Merci
Il y a 1 heure
Peanox : Bonjour, je cherche un nouvel écran principal, j'aimerais bien du 30 pouce mini, 100hz mini et 4ms maxi sachant que j'ai une RTX (Donc pas de freesync AMD) et pour le prix je m'y connais pas vraiment donc je vous fais confiance, merci beaucoup :D
Il y a 2 heures
Tosma : Bonjour j ai acheter une carte mère b450 plus gaming tuf de cher asus et j ai pris des j’arrête de ram corsaire 3600mhz et j aimerais savoir si c est compatible ( je n ai pas réfléchi )
LoulouNoped : Bonjour, je veux bien un avis sur mon post pour m'aiguiller, merci :)
SyMo21 : Bonjour à tous !
Je fais appel à vous pour m'aider.
Je me suis monter une tour y'a un mois tout fonctionne très bien mais je remarque que les ventilos de la CG tourne à fond pendant 3-4s au démarrage de l'ordi.
Après des recherches sur Google, il n'y aurait rien d'inquiétant, je demande donc confirmation ici et est-ce qu'il est possible de régler ça ?
Msi Rtx 2070 super gaming X
Raikou : salut
j'ai acheté un Sound BlasterX G6 et en casque jai un hyper x cloud 2 je n'arrive pas a avoir une spatialisation du bruit des pas meme en scout mode merci de votre aide
lilynb : Bonsoir,
j'aimerai vos points de vue d'expert :budget max 1000 la tour.
Logement: PURE BASE 600
Tour - ATX- insonorisé,
Alimentation standard: Silent 650 Watt
MSI Z390-A Pro
Intel Core i5-9600KF, 6x 3,70 GHz
Refroidissement :Silent Tower Cooler: Alpenföhn Ben Nevis
RAM: 16 Go
Sans SSD M.2
1. Disque dur HDD 240 Go SSD
2. Disque dur HDD / SSD: 1000 Go
Carte graphique: AMD Radeon RX 5700 XT - 8 Go
tnfrance : @thomas86, je t'ai répondu
Thomas86 : Bonjour, est-ce que quelqu'un peut aller check mon post forum s'il vous plait, j'ai besoin d'un conseil pour le Black Friday et j'ai peur de m'etre fait inonder sur les post plus récents... Merci !
Ps : c'est pour un changement de CG Et/ou CGU
BaptSama : Bonjour à tous, petite question je souhaite changer de casque, je dispose actuellement d’un hyperx cloud 2 couplé à un mixamp et je voudrais partir sur un G pro X et donc je voudrais savoir si je peux utiliser la technologie blue voice et le dts 2 avec le mixamp.
Merci d’avance pour vos réponses
liloune : Salut, je suis un peu désespéré, j'ai achété un zboard wow mais la partie jeu ne fonctionne pas. j'ai tester plusieurs config, rien a faire. La j'aimerais pouvoir convertir un fichier txt en inf mais sans succés. Merci d'avance pour votre aide
Fawkes : @dnx2222 : 3070
dnx2222 : Bonjour, a votre avis pour une nouvelle config plutôt rtx 2080 super oc gaming ou Rtx 3070 ?
Il y a 5 jours
Grith : Je suis dans le même dilemme que toi Sam3dArt ^^ Le choix est pas facile. Après avec les histoires de stocks si on veut pas se faire racketter on a encore quelques semaines pour y penser ;)
Il y a 6 jours
malelo : bjr, je comprends pas apparemment
j'ai 2 réponses pour mon sujet mais je ne les vois pas !!
Il y a 6 jours
holdusback : Franchement la config a énormément tourné et été super costaud mais après 3 ans je commence a sentir qu'elle faiblit ahah
Il y a 6 jours
holdusback : Si quelqu'un a un peu de temps, après 4 ans j'aimerais faire évoluer le PC qu'on m’a aidé ici a monté, j'espère que je n’ai pas fait de bêtises sur le topic !
https://www.config-gamer.fr/forum/4-config-pc/55584-evolution-aide-pour-l-evolution-de-mon-pc-mao.html#281042
Il y a 6 jours
Yomdegui : pas de doute si on suis les test vu cet aprem, les CG Nvidia sont supérieures aux AMD, de toute façon aucune ne sont dispos :-(
Il y a 1 semaine
Sam3dArt : Coucou all
Il y a 1 semaine
Yomdegui : Au niveau des CG, le pire c'est quand tu es prêt a dépenser tes brouzoufs et que tu peux pas :O
Il y a 1 semaine
rsky91 : merci
Il y a 1 semaine
Stiouf : Aucun problème
Il y a 1 semaine
rsky91 : question rapide, mettre une CM tuf avec une CG rog ca pose pas de soucis ? ou c'est mieux que ce soit de la meme serie ? (les CG tuf sont moche faut le dire)
Il y a 1 semaine
Sam3dArt : Aie aie aie demain Amd et en hésitant sur la 3070
Laquelle choisir?:O p:S pour ma nouvelle cfg
Il y a 1 semaine
Grith : Après vu les résultats du DLSS sur les perfs ce sera surement net avantage Nvidia jusqu'à la sortie d'éventuelles cartes dans le segment de prix du dessous. (Du coup j'vais surement passer vert, j'ai pas envie :S)
Il y a 1 semaine
